Well, I got the Creative Steel rack bushings installed.
Only thing nearby I needed to unbolt was the front mount for the front diff; 3 bolts and pried it out of the way. also removed the trip pan for the oil filter for clearance.
was able to press out the old passenger bushing relatively easily,but the driver side one fought me tooth and nail. finally got out the blow torch and set the rubber on fire and heated up the old steel bushing. THEN it came out.
so those are done, oil change, spark plugs (just shy of 40k miles, yea I was naughty. they all meaures in at a 0.045-0.055 gap), extra rear isolator (frankly the ones that were there were pretty crushed anyways), greased all the front joints, installed the new tires that were put on the MOABs.
245/75R16 doesn't rub on the left front, but the right front *just* touches the front fender liner, right where the windshield washer pump sits, causing the pump to leak at the fitting on the tank. It's because the diverter valve for the front and rear sticks out towards the back, and the tire is pressing in it there Ironically, if they'd put that diverter parte at the TOP of the pump instead of the BOTTOM, there wouldn't be an issue. So... anyone know of a replacement pump with the diverter at the top?
the blue part, move it to the top!
or even some kind of extension or relocation kit for the pump that'll still suck from the OE tank?
