Had to do some research. My compressor didn't come prefilled with oil. There is some shipping oil to prevent corrosion, but not enough for operation... So, check the videos....
Well, crap. They are too big.... So you must suffer while I type...
So you need to add 4oz in the compressor, 4 in the accumulator. The compressor goes in the suction side... See Pic where I point with the pen... Add about a half shot of oil, spin the compressor clockwise (use a pin spanner or a pair of slipjoint pliers to spin the core of the clutch. Obviously spinning the outer side of the clutch does nothing, as the clutch is just going to do it's thing without power.) You are pumping the oil through the system..
At some point the compressor will likely build pressure and blow off the shipping plug on the output hose that the factory attached, blowing oil on you. I took this as a hint she's full. (EDIT - You should really take off the plug, raise the hose, and get the full 4-ish oz in there...)... Then put the shipping plug back on, and put the compressor on the clutch end somewhere it won't fall and break. Let it sit there for about 5 minutes to lubricate the front seal, else damage occur when you run it.
It doesn't seem the amounts are critical. Just make sure you have about 8oz in the system. The manufacturer didn't say it was prefilled, and they included an 8oz bottle in the kit, so I took that as a given the entire bottle goes in the compressor and accumulator. It's all going to homogenize once activated.
Again, MAKE SURE to spin the compressor while filling into the intake port, and stand it on the clutch end for at least 5 minutes afterwards. I would not let it stand for very much longer than that, and give it at least that amount of time you let it stand (out of position) in the proper position (ie, installed.). Anyone who ever moved a refrigerator flat and then wondered why it didn't work when they got it home can tell you why. The oil needs to drain back where it belongs. So let's stay around 5 minutes, because that's what the manufacturer said and if you can reassemble an AC system in less than 5 minutes... Well, I don't want you working on my stuff....
(note to MFR.... is it really THAT HARD to add a darn sight glass to indicate oil level?)
