- Joined
- Dec 17, 2006
- Messages
- 10,612
- Reaction score
- 43
Yeah as soon as it through the code for the P/N switch it narrowed the search down to one part,a expensive part also.
The ASD relay stands for "Automatic Shut Down".All 6 injectors and all 6 coil packs recieve + battery power from the ignition switch,the PCM houses 6 seperate drivers for each coil and another 6 for the injectors by switching "on" the ground.The ASD relay is the final circuit in that ground path(along with the fuel pump power).Your going to start having to go through each wire in the harness and test the PCM to find the problem,best of luck(dealertime if it was my KJ).ridenby Having similar problems,swapped out ASD relay,with blower relay,Jeep started.Next time I went to start,no go,swapped another relay to ASD spot,Jeep starts. what is ASD? Where do I start looking for the cure?
