ravimehmi0321
- Joined
- Jan 31, 2026
- Messages
- 1
- Reaction score
- 0
Jeep Liberty (Cherokee) KJ
Electrical faults improved, not worsening.
Glow Plug System
Improvement, but still no start
Fuel System – Current Focus
Observations
Points to fuel pressure / injection enable issue
Rail Pressure (Live Data)
Fuel supply improved but problem persists
Current Symptoms
- 2.8 CRD
- 2007
- Manual
- UK vehicle
- Crank but no start
- Would cough occasionally
- Glow plug light intermittent
- Multiple communication faults originally (BCM/PCM messages not received)
- ECU bench tested (Autotronics) – passes, 5V reference present
- VINs match (PCM / BCM / SKIM)
- No immobiliser active
- Crank signal present (seen on OBD)
- Cam signal now confirmed
- Throttle pedal not responding because engine never enters run state (expected)
- Glow plug module originally floating loose (not grounded)
- Battery negative → alternator bolt (35mm²)
- Alternator → bulkhead (35mm²)
- ECU ground cleaned
- Bonnet strap replaced
- Temporary jumper lead from engine to battery negative made glow plug light behave more consistently
Glow Plug System
- Original glow plug control module:
- No audible click
- Glow light very intermittent
- Replacement Bosch module now fitted
- Glow light now:
- Comes on for ~2 seconds
- Only returns after key-off rest period
Observations
- Fuel present at injectors (cracked lines)
- Engine will run briefly on Easy Start → confirms:
- Compression OK
- Timing OK
- ECU can run engine if fuel injected
- Engine dies immediately when Easy Start stops
- While cranking:
- Ranges from ~150 psi up to 800–950 psi
- Only reaches higher values when glow plug light appeare
- Does not sustain pressure
- Pressure collapses quickly
- P0093 – Fuel System Large Leak Detected
- Appeared after recent testing
- Was not present earlier
- Hand primer bulb:
- Goes soft while cranking
- Loses pressure at rest
- Installed HEP-02A low pressure electric lift pump (3–6 PSI)
- Temporarily mounted in engine bay near fuel filter
- Inline filter before pump
- OEM filter still in place
Current Symptoms
- No self-start
- Runs only on Easy Start
- P0093 active
- Rail pressure builds but drops
- No RPM shown on dash (RPM visible on OBD)
- BCM overhead display not updating
- PRV (Pressure Relief Valve) leak test
- Remove return hose from rear of rail
- Check for fuel during cranking
- Injector leak-back test
- Bottle test on injector returns
- Verify lift pump placement
- Possibly move pump closer to tank (push vs pull
- Battery voltage under load
- Drops to ~10.7V while cranking
