DRL activation?
jeeptorino68
Oregon
i have seen some info on this online, and was curious if anyone has any other info on it.
i see there is a sport or a DRL relay. from what i read the BCM has to be reset to canadian for this to work, is that the only way?
Billwill
White River, South Africa
You have to remove the High Beam relay and next to it insert the special DRL relay with large heat sinks.
Then as tkj2002 states you need the dealers to re-program the country code.
jeeptorino68
Oregon
hmmmm
ok
thanks just wanted to be sure the info i was finding was right and there were no new developments on this issue
