2002 Jeep Liberty Sport Right Low Beam not working
cg206
Hi, I have a 2002 Jeep Liberty Sport that has some kind of an electrical problem. I have tried everything I can think of, and it is still not working. So, low beam on right side (passenger) is not working. Everything else works, turn signals, fog lights, high beam.
I have changed the fuses, verified the relay works by exchanging with the high beam relay with the low beam relay, exchanged the head light bulbs to verify the bulb is good (it was new, but who knows). I read that sometimes it is a grounding issue, so I cleaned the one found under the oil filler but still the low beam on the right side does not work.
Any other suggestions? I am at a loss on what to try next. Thanks
Ian Glass
Not sure if you came right with the RH low beam not working? Easiest fix is to run a new wire from the LH low beam to the RH low beam. Just check that the low beam fuse can handle double the current! Not very technical but an easy fix never-the-less!
cg206
Ian, just now reading this. Not sure I follow, can you explain in more detail?
Have you checked to see whats missing right at the plug? I'm assuming its missing the low beam + power since the high beam works... You should have a good ground.
If its missing +12 volts at the plug, go to the relay and see if its getting +12 volts into the relay. Just gotta work your way back to see whats missing and where.
This is from my 2004 manual, your 2002 may be different, idk??
Ian is saying that you should run a wire from the right headlight to the left headlight, but I do not recommend doing that since the load of two headlights would be on one 10amp fuse.
