2002 Liberty Needs what at 65k miles?
J33Pfan
NY
Hi everybody!
Lookin to buy a 2002 - 2004 4x4 Liberty for my daughter.
What kind of major maintenance needs to be done at 65k - 70k miles?
such as timing chain? water pump? alternator? sensors? etc?
thanks in advance :fish_h4h::fish_h4h:
If not done before or unknown history..................
Replace every single fluid(coolant,brake fluid,trans,diffs,t-case,PS fluid),replace spark plugs,replace serp belt and tensioner.
All are due by time or mileage.
I will always say.. have a full point safety inspection done before you buy it to start with.
Have a proper pro ODD2 scan done for any codes.
If the owner or lot does not have full history, having a car fax, no accidents leans etc is important to.
With no history and those miles, all fluids should be changed out.
Pressurization test w/ new thermostat w/Hoat coolant, rear diff serviced, front & rear transfer cases, transmission serviced, power steering flush (Atf+4) Even new brake fluid DOT3 if it fails a brake fluid test strip.
Timing chain is life of motor, water pumps can be checked for flow but last a long time if the right hoat coolant used.
Alternator same but check output voltages and battery, load test it.
JasonJ
Michigan
I'd say a 12-14 year old Jeep with that low of miles needs to be driven more!
No seriously, just sitting there is not helpful to the vehicle at all. Check any rubber components for dry rot, cracking, brittleness, etc.
When I picked up the 03 last fall I went through it all.
All new fluids, filters, spark plugs ( which was good since they had crappy plats in it) in diffs, transfer case , drained , flushed and filled cooling system etc
Also put it up on stands and went through all of the hoses underneath, and then around the engine
It only had 81,000 miles but found some dried out/ cracked hoses etc
J33Pfan
NY
ok great info! Thanks!
how long do the original brakes last and should there be any sludge or black oil film where you open the oil fill cap?
anything else I should look for to tell if its really a low millage car??
Brakes all depends on where you drive, how you drive etc. I generally get about 100,000 out of a set of brakes on the KJs but some only get 50-60,000 due to riding the brakes more or always stop and go intown
Oil fill cap will look black but do you have a picture??
J33Pfan
NY
no pics. i havent seen it yet. i just want to know what to look for on a real low millage car.
** if i run the engine with the oil cap off will there be a little blow by or a lot pushing out on a low millage jeep?
J33Pfan
NY
Ok, so I went over the car and noticed too much rust on the frame & door bottom. the engine compartment was covered with a film of oil. Overall the car was lookin worn out. The engine had a bad miss, so with all that ... I told the seller that it wasnt a 64k car. The odometer & plastic screen looked so new yet the rest of the car looked like a 250k car. so off I went!:signs16:
