Ok, so my front passenger window is stuck in the up position. I thought it was the motor and purchased a new one. But before installing the new one I decided to test it outside of the door. Well when I plugged the new motor and hit the switch nothing happened, just like nothing happens with the old motor.
So, I used my multi-meter to test power at the plug and i'm only getting 11.12 volts instead of the nescessary 12. To confirm that this was my problem I tried the new window motor on the driver door and it worked.
My question is what would cause the power to the plug for my front passanger window motor to drop voltage from 12 to 11.12.
thanks for the help in advance...
