1BADKJ
Will a set of renagade flairs fit a sport. I like the bolt on look.
Just remember that '02-'04's can only use '02-'04's Renny flairs.For '05+ KJ's you need flairs from a '05+ KJ as the older flairs will not work.Sweet. Now I need some flairs.
I'm sure you already know this but some may not.
Why won't an 04 05 flair fit my 03.
The rocker panels are different between the '02-'04's compared to the '05+ KJ's along with how the flairs meet the front bumper.I want the shorter flair so I don't have to cut it.
I think I picked up an '05 front flair when I was wheeling the last time in the Pines. I'll bring it Saturday. No guarentees that it's an '05, but I have it in my garage at my house in Ewing (I'm in North Jersey now for Spring Break) and can just throw it in the trunk next time I'm back there.
We can see if we can make it work. There are quite a few clips underneath the flair that hold it to the body. There is also a triangular support piece that just helps support it which it can do without (mine's actually slightly broken from hitting my ex's car). We'll have to see if those will allow the '05 on.
I'll inspect the flair a little closer next time I'm back in Ewing to see if it's really an '05.
Ok the question now is... Will 05 and up front flairs fit an 03
That's what we're trying!
Yea. I'm not using the bumper at all. Going tube. A to Z fabrication is going to come up with something. I'll find a place to put blinkers. Even if I have to use blinker fluid.
