Hey guys what aftermarket transmission cooler would you guys recommend?
also what fittings would I need? or does the cooler come with the right fittings?
it's for a 02 liberty limited none towing package thanks guys
Well since you have a '02 with the OEM ****** cooler already in the radiator you need no special fittings except for a 3/8" double barbed connector.I used a Hayden ****** cooler from Advance Auto Parts,about $40.
In the pic below is how I hooked it up.
1---is the lower ****** cooler line(yes it looks to be the upper but it is not),I unhooked it and ran it to one of the AUX ****** cooler inlets(doesn't matter which one),the hose is supplied with the cooler.
2---is the cooler soft line taken off the metal line,use a 3/8" double barbed connector to hook it to another rubber line and run to the other AUX cooler inlet.
Make sure all hose clamps are tight,add about 1/2qt of ATF+4 to the ******(how much I had to add).
The fun part is attaching the AUX ****** cooler to the A/C condensor with the supplied zip-ties,I would remove the fan to gain better access to the other side of the radiator.In the pics below it shows it behind my grill.
