What is your recommended Liberty and Options?
Teac
The Liberty seems to be capable while being good value. Are there any model year or feature/options I should consider to seek out? In the same context, are their ones to avoid and/or common issues?
Being in the PNW, I would like to explore on the weekends.
Kind Regards
duderz7
Weiser, ID
'02-'05 generally have less electronics such as traction control and all the fun that comes with it. I think drive by wire happens in '07. Some folks like the electronic gizmos, others don't. Any of them can be built into a great trail rig. Happy Hunting!
klc
“It flies like a truck.”
PNW
Kind Regards
Welcome to the neighborhood. I bought mine for the same reasons. Check for rust underneath, and make sure all the recall work is done.
02-04 are the best
But 05s will work almost as well
check rust
lower ball joints
v6 only the 4 cylinder gassers are dogs
Limited edition have later interior
Doing10to20
Kind Regards
They can be capable but you gotta out work into them, alot. Basically the IFS will be your biggest hold up along with the wheel wells. If you wanna do some mild exploring for the most part you'll be fine but once you wanna get more aggresive it takes time and some money to dial it in. I ended up with mine out of necessity and then it morphed from there. Get you a Cherokee XJ or grand Cherokee ZJ or WJ you'll spend a bit more from the get go (zj and wj will be cheaper) but you'll be able to do more long term exploring wise. I've taken my KJ everywhere but there are better rigs out there, if it was a solid front axle then it be a monster for sure.
WheelNut
Vancouver, BC
I know a lot of guys recommend going for the older models as they have less electronics, but having traction control and such can be awful nice in the winter- especially if you are sharing the vehicle with someone who has less ability to catch a slide or manage wheelspin. The girlfriend has had a few scary moments in my KJ and I really wish it had some electronic nannies. AT tires are pretty bad grip in the cold rain. Combine that with a tall vehicle that has a short wheelbase and you’ve got a vehicle that isn’t inherently stable. Personally if I were to do it again I’d get a Land Rover LR3 for a little bit more cash. The KJ is good in the city though since it is so short, it is very easy to work on and the parts are cheap. Lots of good help here in this forum too. The KJ is definitely an underdog and most people think its a shitbox, so that can be appealing in a way, haha!
I’d look out for gunk in the cooling system as these Jeeps need a particular coolant and lots of people put the wrong stuff in which clogs up the heater core and other stuff. The coolant tank near the fire wall shouldn’t have any coagulated gunk in it. Make sure the heater blows hot! Fixing the heater core is a major PITA.
Common issues are front prop shaft boots failing and taking the U joint with it (easy fix), fan relay failure where the low fan speed doesn’t work anymore (easy fix I’ve heard), and outside of that there isn’t much abnormal issues you wouldn’t see on any other SUV. They wear out ball joints, shocks and tires just like anything else.
Try to find one with the heavy duty cooling pack and skid plates as well. The standard cooling setup is one small electric fan. Look for a big plastic shroud surrounding a clutch fan and you’ll know it has the HD cooling. If you can get a Renegade jump on it! They have the full skid plate package and HD cooling. Getting a set of skids is expensive, so it can save you a lot of cash.
You’ll also notice there was a refresh of the front end in 2005. IMO the early models look better, but you can choose from either front end.
That’s all I can think of for now.
