New front shocks showed up - just waiting for the rears.
Do you have any lift out back, and if it's 3" or so, what shocks are you running....New front shocks showed up - just waiting for the rears.
I have a 2" lift on my truck - rear shocks are the longer Bilstein #33-185859. The front is technically not a strut but a shock with a coil over spring.Do you have any lift out back, and if it's 3" or so, what shocks are you running....
Wait.. These don't appear to be Struts for the front... Have I gone stupid?
Idk if you’re aware, but these KJs are very high performance machines. Very sporty. D&S rotors are a must.I think drilled and slotted is more about heat, allowing air to pas through, but logically seems like it might also give space for water and or debris go so the pads can make contact. I've considered them myself, but decided it wasn't worth it to me. I believe they wear quicker too.
What part number you using on the front, which springs F/R did you go with.I have a 2" lift on my truck - rear shocks are the longer Bilstein #33-185859. The front is technically not a strut but a shock with a coil over spring.
Please explain how the front isn't a strut....I have a 2" lift on my truck - rear shocks are the longer Bilstein #33-185859. The front is technically not a strut but a shock with a coil over spring.
Traditionally a strut is attached to the steering knuckle and helps support the knuckle and also turns with the knuckle versus a shock which only helps control the up down movement of the suspension.Please explain how the front isn't a strut....
The fronts are #24-139168 - my truck has the H&R springs with a few conduit nuts up front for an extra 1/2" lift.What part number you using on the front, which springs F/R did you go with.
Nice-Yeah I seen the ARB ones, those look cool I like the drain and fill plugs. I missed a deal to get one from a damaged lost misdirected freight. Do you know how thick those are. The one I was looking at, not that I would need a beefy one was from RuffStuff, see pic. its 3/8 think welded, but it's pricey like $150 not as expensive as ARB's. "The 3/8" plate steel cover is bent 8 ways and welded to a massive 1/2" ring, giving unmatched strength and sealing performance—perfect for off-road abuse or heavy-duty daily use." Nice, but doesn't have the cool looking design.Though this is what is waiting in the garage for me to put on —You must be registered for see images attach
I have the red one. You will like it.Though this is what is waiting in the garage for me to put on
That's a McPherson strut you're describing. Rest assured, the KJ DOES use front struts. At leaat my 05 does. They aren't a McPherson strut, no, in that it's not an alignment/structural part of the assemblage.Traditionally a strut is attached to the steering knuckle and helps support the knuckle and also turns with the knuckle versus a shock which only helps control the up down movement of the suspension.
You have a Chrysler 8.25, looks likeTrying to determine what rear axle I have in liberty, 2007 build sheet stated corporate 8.25 i seen a similar reddit pic dana 35 looked like mine but mine is flat on bottom. Any help would be great.
