Well i had the TCC light come on and off for a while now, tried flushing ****** fluid and was hoping it was just a fluke and fix it. But yesterday i was using cruise control and going up the hill it down shifted and upshifted again really really hard with a bump and then my 4th gear went out. So when i got off the highway and stopped at the light it downshifted with a bump again and would not even go anywhere. I tried putting it into 4 hi thinking it might just drive me off the road and it moved for 10 feet and completely quit working. When I tried it again it was grinding in the reverse. So after getting it towed back, I am now looking into buying a donor trasmission since it is the cheapest way and either doing the swap myself or having a shop swap it.
So my question is for the 05 Libberty 3.7 L 42RLE can i use 05-07 or any year after 05 will work? Also when I was looking at the transmissions it gave an option for a 3 or 4 wire plug on the LH side, so does it really matter which one?
Thank you guys/gals, and also if you have any links for videos or any other usefull information to accomplish this task on my own please share.
