Thelt
I just bought a 2005 Liberty and the front end sits pretty low compared to the back end. It has a fairly solid rake to it. After reading on here about how the coil springs wear out so fast I am thinking that my front springs have worn out a lot more than my rear springs.
Do I need to replace all 4 springs or is it acceptable to just replace the front springs? I have read good things about the OME springs on here. If I get a set of them is it required that I replace the struts at the same time?
I am not looking for optimal lift (although lift would not be a bad thing) I just want to fix my sagging front end without spending a lot more than I have to, or fixing it in a way that will give out again fairly soon.
