Parking Brake 2002 Liberty
Logan Savage
WV
2002 Liberty with drum brakes on rear . Just installed new brake shoes on rear & parking brake lever will only pull up about 3 clicks . Brake shoes didn't appear to be spread at the top as if parking brake cable was too tight when shoes were installed . Wheels turn freely with parking brake released & brake pedal is very good . Other vehicles I've had , the parking brake cable could be loosened or tightened .
Don't seem to have any problem as is but was just wondering if there's a way to loosen the cable so the the parking brake lever would pull up farther ?
CactusJacked
Chicago Suburbs
There's no reason to need the handle to pull up further than it is, provided the brakes are holding when up and releasing when down.
turblediesel
memberable
Alaska
I removed the center cubby and console on my '05 which has discs. Guessing the lever end is similar. Two adjusting nuts tightened or loosened in a balanced manner. A trammel bar sort of arrangement. Mine was floppy loose new.
You have the rear brakes set just right if the P brake lever clicks only 3 times and holds but the brakes spin free when off.
