Need help installing 4xguard rocker covers
KJ604
Vancouver BC
So going to install my 4xguard rocker covers. It says test fit the bolts through the pinch welds of the rocker panel and that there should be 6.
i cant see any holes on either side. on both sides there are 2 bolts towards the front. do i need to remove those ones? that still only leaves 2 holes at the front on each side so does this mean I need to drill all the other holes?
I think you'll need to drill. Those two front bolts are for the fenders, just leave them.
CzarKJ
Townsend, MA
If I recall I had to drill
Here is my test fit.
KJ604
Vancouver BC
So how the heck do you align the holes so the thing is in the right spot??
Man Im moving in 3 weeks and I have so much stuff to do. I wanted to throw these on quickly and be done with it. Now going to have to wait until after I move.......
In your test fit pic, what is holding the front of the guard up? I see the floor jack on the back.
CzarKJ
Townsend, MA
I put it in place with the jack. Aligned it. Marked. Then took it off and drilled one hole. The put it up with the bolt and marked. Rinse repeat.
KJ604
Vancouver BC
Ok thank you. Do you have any pics with the doors open?
John3seventeen
WV Panhandle
Front bolts need removed it uses those holes, you can also make a template from the 4xguards and clamp it in place to mark for drilling
KJ604
Vancouver BC
The two bolts towards the front on the pinch weld ARE two of the mounting holes?
Thats helps at least there is SOMETHING already on the body to help me line it up.
Ocelot
Manitoba
does nayone have a link for these 4xguard rocker covers?
I can't find it
