ronjcar
I'm currently at 3 inches of lift with 31s. How high do i have to go to get 35s on this thing? Is it possible?
Not going to happen with IFS still unless you want to drop $50k+ to have a IFS system fab'd up to clear 35" tires on a KJ and be able to turn.You'd also need to gear to at least 4.88's which means the D30A must go and you have to grind teeth on the ring gear to install the center pin for the 8.25 rear.I'm currently at 3 inches of lift with 31s. How high do i have to go to get 35s on this thing? Is it possible?
Spent less SFA'ing my KJ to run 35" tires then buying a TJ and modding it(correctly) to run 35" tires.By the time you finish fabbing for 35"s, you could already have built up a nice little TJ and fit 35"s to it...
ain't nuttin' in this world a man can't solve with a cuttin' torch, a welder, and some beer.
i had an elcamino on a f240 frame up north for a while it was coo as shit
