johnnygrace
Hey Guys,
So I inspected my front drive shaft, 2004 Liberty 3.6L, as was recommended multiple times on the forum and of course the Transfer case side CV joint boot was obliterated so I assumed that had to be my problem. (see photo below) of course I'm glad I did because that definitely needs to be rebuilt and I'm even questioning whether to do the front joint as well as it sounds like there's no grease in the boot even though it's still intact. (another question I have is wether to just buy a new shaft from driveshaftparts.com or rebuild existing shaft, any difference? anyone have a strong opinion about that?) After going for a test drive without front shaft the noise was still there. I looked around the tires and there aren't any u-joints there to check and I pulled on the rear driveshaft, the backside seems to have no play, the front has a little bit of play but not so much. So the question I have is.... what should I check now?... brake calipers? Can anyone point me to a good tutorial for that. Is there anything else y'all can recommend checking. As well should I just pull the rear driveshaft and rebuild that anyhow. It's obviously never happened and the car has 135,000 miles on it....almost never use 4wd, light city driver so don't need anything crazy burly/expensive.....thanks in Advance!
In summary: Angry Sparrows
-not caused by front drive shaft CV Joint despite boot obliterated
-Small amount of play in front most rear drive shaft u-joint but very small never been rebuilt in 135k
-What to check now, brake calipers? any other suggestions?
as well: Front Drive Shaft
-Rebuild drive shaft with parts from driveshaftparts.com? or buy new shaft w/joints instead of rebuild? Or scrap that website and order from completely different place. Keeping expense as most important and car will probably have to be replaced in a few years anyhow.
