For the last 2 or 3 years I've been getting intermittent abs eps tps alarms and the car will go into limp mode. A day or so later it will go away by itself. Had my mechanic and dealer look at it with no luck. Think I found the problem. I opened up connector C100 83 pin connector behind the left kick panel. Found green corrosion inside the connector. Cleaned it up but bent a pin but it didn't brake. So far so good everything works. My question is can I replace this connector or it's pins?
Thanks!!
Thanks!!
