abs eps tps alarms found problem????
wb2kki
PA
For the last 2 or 3 years I've been getting intermittent abs eps tps alarms and the car will go into limp mode. A day or so later it will go away by itself. Had my mechanic and dealer look at it with no luck. Think I found the problem. I opened up connector C100 83 pin connector behind the left kick panel. Found green corrosion inside the connector. Cleaned it up but bent a pin but it didn't brake. So far so good everything works. My question is can I replace this connector or it's pins?
Thanks!!
if you can find the actual part number, sure.
You might as well just change the entire connector.
Rockauto has
ABS Wheel Speed Sensor Connector
replacement that you can cut the old connector out and spice a new one in.
wb2kki
PA
This is a 83 pin connector off a main harness. I called the dealer first he said it is not serviceable then he said they can change the pins. Mean time it is back together and working and I put some plastic around it in hope to keep it dry. No sign of water other than the corrosion on the inside of the connector.
blackhawk
Venezuela
Is it possible you to uploaded a pic?
