04 Liberty - Loud noise when unlocking driver door
revhard
Canada
A loud noise comes on every time the driver's door lock is unlocked. From what I've read it appears to be the door lock latch/actuator that's causing it. Local dealers are asking $260 for the part (#55177043ai) so I've decided to take it apart this weekend just in case it's something that's fixable. From the pictures below you'll notice some of the teeth on the plastic gear (marked in red) have worn off so every time the medal gear from the motor engages and hits that area, it makes this screeching noise.
Any chance someone has replaced one of these before? If not, think it's even possible to pick one of these gears? I'm not optimistic at this point but thought I'd ask anyways. Thanks!
Porkchop
Troy Mi
How about a pick and pull visit. Might find some other goodies when your there as well.
revhard
Canada
yeah I tried local auto wreckers as well with no luck. I found some salvaged ones at an auction site however they won't part with the latch assembly
