2005 Jeep Liberty Not moving when in D
Jrdnl12
2005 Jeep Liberty Sport 3.7L V6 Automatic
I’m having troubles when leaving work. Everytime I fire up the vehicle and start leaving my parkade I need to come to a full stop to allow the garage door to open. When I do the vehicle will no longer move when in drive. I have to restart the vehicle/ try moving the vehicle from R to D to get it to start moving again.
The whole time the engine is still running and the rpm’s still go up when I hit the gas pedal just feels like it isn’t grabbing a gear.
Would love some ideas as to if anyone else has had this problem.
Firstly I'd Check ATF+4 Transmission fluid on level ground. Is it showing correct level on dipstick?
Possible that the shift interlock cable is not adjusted properly?
Hopefully others may chime in with ideas...
I suppose the next step is also to have a Transmission shop read any stored or pending codes.
Clutch volume index %... = ?
Jrdnl12
Thank you for the help! I’ll take a look into it, it’s not shooting any codes yet but we’ll see.
You need a shop that has a professional snap on Modis ultra scanner !!;)
Jeremy-WI
Home
Mine does this every once in a while and it is also leaving work, but adding 4-8 oz of fluid to the transmission makes it work again. I should drop the pan and change filters
reconpatrol
Mine has the same issue some years ago and the reason was been the trasmission oil pump , a very big headache I have had to demount alla trasmission to change it , it was a leak in the pump ,try to put the shift lever in neutral for a bit then in D if it moves normal the reason is the same
