Blend Door Actuator help? 2003 Liberty 3.7L Sport
Spottedbat
I am looking for help regarding this blend door actuator frustration. The metal splines as seen from below it just spins around nonstop in one direction of cold and then the reverse direction for hot. it is my understanding from other research that it is supposed to have a stopping and starting point. Perhaps there are different designs of actuators for different years or car models. Here are some of my videos. I just got this used 2003 liberty 3.7 Sport that had no heat and previous owner had worked on. They had done a heater core flush. Not sure if they properly bled the coolant but i will be looking into that. The vehicle would only have slight heat coming out of dash if you had it on level 1. If you turned in up it would be cool air. They opened up most of dash but not that final piece to pull back so i am having a hard time trying to get to the actuator. I had found and corrected a few major vacuum leaks so fortunately now air is blowing not only from the default dash position. All positions work but the heat is not very hot just warm and the passenger side is warmer than driverside. Its an improvement but winter is cold in Maine so i would like it hotter in the vehicle... All the other actuators are pushing their rods when the controls are moved so i think this actuator is an issue since it just makes its whirring noise nonstop and spins its little gear. I was hoping to get it out of there tomorrow its that last screw in the rear that I can't release. maybe its missing a part? there is a square hole in the bottom of the spline one could stick something in. People talked about using a tool on there but i think it was for a different model or year...
here's some videos
Reply
Report Edit
Spottedbat
It took a long time but I finally got the actuator out unfortunately it was probably in working order but trying to get the back screw off while melting the plastic around the screw I got too close to the inside and messed up the plastic next to a worm gear so that's too bad. Finally found the problem when I opened up a bigger hole on the HVAC box.The door hinge had gotten off track and was outside of the nubs that go against its top mount. I was about to give up numerous times. I finally managed to get the door turned around and somehow by a miracle it found its place back in the slot which previously was a hole that the spline would spin around continuously. I really hope when my new actuator comes it sits in there perfectly and doesn't strip or break this damn door! What a struggle. I hope if this happens to another 2003 Liberty owner they can at least find it useful.
