Why no daytime running lights on KJ?
feetwet
Maple Grove, MN
I'm a bit surprised Jeep doesn't offer DRLs on the KJ... any thoughts why this is? I actually like having them in certain light situations...
fasto82
NE PA
I do not like them and hope they never become a standard. all they do is kill your bulbs quicker. its easy if you want DRL's, just turn on your headlights. there ya go. just as simple as that. Thank you Jeep engineers for not implementing that into the KJ's design. I mean in broad daylight if you cannot see a car coming then you should not be on the road yourself. does anyone else feel this way?
MoladoGuy
DeTrOiT (Actually Warren)
I dont feel that way. DTRL's are designed for low light visibility such as rainy/cloudy days or dawn/dusk times. They increase the visibility factors, allowing other drivers to be more aware. Also DTRL's reduce the possibility of drivers not turning on any markers or lights during fog/rain/tunnels, which can be a hazard.
FWIW I only had DTRL's when I had a Grand Am. I never had a complaint with them though. Not everyone has "Broad Daylight" all the time.
AnthologyCT
Detroit
Daytime Running lights
Does anyone know what would be needed to add daytime running lights to KJ's sold in the US that don't have them?
Is there some type of module that could be bought from a mopar dealer and installed?
Can anyone find out? I would buy the part and install it myself.
feetwet
Maple Grove, MN
My sentiments exactly... for example, on my way to work there I drive through a low area that tends to get a light fog across the road.... also good in a light rain, etc.
Gentleman
8' Below Sea Level
Re: Daytime Running lights
On the fuse panel on the side of the dash near the top is the relay for the headlights, next to it is an open space, you need the DLR relay, it plugs into the open space and the headlight relay needs to be removed, this is a special relay you cannot use the headlight relay, will this automatically give you DLR's, I don't know, you would probably need to get the some sort of BCM programming
k99jk99j
ohio
in my 06 in the relay box in the car there is an open relay spot for day time driving lights. i don't know if it just needs a relay or more work is involved? mike (flagusa)
feetwet
Maple Grove, MN
Can one of you Canucks (or others with DRLs) post an image of your fuse box for comparison? Also note any part numbers on the DRL relay and the headlight relay.
hyde
I don't care much about the d.lamps, it would be a nice addition to jeep, PLUS it saves money on your insurance (considering I paid 6400 the first year I had my jeep!!!) anyway, it saves a bit..
I care that if KJs had auto lamps. At least the Limited model. There are three things missing from KJ LTD that I really would love to have, Auto Headlamps, Climate Control and Dimming side mirrors. All these were on that famous G.C. we had which was '96 or '94 something like that.. It is fairly simple to turn on the headlamps manually but lazy man wants them auto :)
Or they could have made it react to the time on your Jeep's clock OR they could have linked it to the wipers.. Wipers On = Lights On.
especko
Kaukauna,WI
i would rather have the auto lights like the grand cherokees have. personally if you wanted daytime running lights why not just turn your headlights on whenever you drive?
priell3
Or the factory fogs if you have them.
Quote from the PA Vehicle Code regarding light usage:
"Any time when, due to insufficient light or unfavorable atmospheric conditions, including rain, snow, sleet, hail, fog, smoke or smog, persons and vehicles on the highway are not clearly discernible to the operator for a distance of 1,000 feet ahead."
Now if people would just follow the rules and use common sense, DRL would be unnecessary. I shake my head every time when I'm going down the highway, it's heavily overcast and pouring, spray from tires everywhere and from out of the gloom a vehicle appears without their lights on. Often the color of the car blends in with the conditions making them nearly invisible until they are close.
I put at least my fogs on anytime I feel I need to make my vehicle more visible. The cost of new bulbs is nothing compared to the cost of an accident.
Marty
Calgary
" if you wanted daytime running lights why not just turn your headlights on whenever you drive?"
Actually, the DRLs are lower beam than headlights.
One more situation - DRLs are VERY nice to see in oncoming vehicles at speed on narrrow roads when you're driving against low setting sun and glare is bad.
fasto82
NE PA
anyone else a non-supporter of DRL's? im sure someone else here has to hate them as much as i do.
waldn
Winnipeg, MB
I believe DRLs use the high beam lights not the low beams and run them at about 40% power
And I personally think they are great
As far as burning out bulbs quicker, the last vehicle I had for ten years, and the only bulb replaced was 1 front signal light
