Renegade overheated today…
Did a little diagnosing and found that the radiator fan wasn’t working.
I have a spare rad fan but that one is a 3 pin. The parts yards is selling the rad fan as much as a new one from rockauto guess it’s time to order one.
I hope the overheating didn’t bother the engine too much. 203087 is my current mileage.
I would play around with the 3 pin and see if I can make it work. In computer fans (very different, I know) a third wire is usually for remote on/off or a PWM signal to control the speed. With 12 volts to the red wire and the third wire, and black to ground, you may essentially have a working 2-pin fan. You could swap the connectors.
I am not saying to do this, just experiment on the workbench with a 12 volt battery and see if the 3-pin fan works the way you think.
LFX1
Bad news…
My 4” lift JBA adjust a strut on the drivers side had a catastrophic failure. The steel shaft of the shock (not sure what it is called) broke off where it joined the clevis. The lower shock mount went flying out, with the spring, as the unit separated into its top and bottom halves. The top half with the shock tube is still attached to the top plate. The bottom half, the clevis fork, is still attached to the lower control arm. The Jeep collapsed down to the bump stop, but only after the abs sensor and CV axle were torn up. Jeepy had to be towed. It is a sad day. She is not driveable and JBA lift kits are not made anymore. I have to figure out what to do.
Did you consider or know anyone who has used those TrakMotive CV's for extended travel for lifts, they have them for the liberty models. I wasn't sure the way that shaft can move in and out for travel would cause vibration on highway, I was looking into them, but haven't heard of anyone using them.
I haven’t heard of anyone using them either. But I have stock CV’s and never had any issues. I have heard of people having problems with aftermarket CV’s where they are a hair too short to remain locked in place when articulated on a lifted liberty. That’s why I plan to reuse the CV I already have and replace the boot that got shredded. It’s only got 230k miles on it after all, lifted since 60k. Or find a low mileage junkyard CV that is also Mopar, if mine turns out to be damaged beyond repair.
CherokeeLiberty
Northern MN
The AC is out on both my Jeep and my wife’s Mariner. I’ll be grabbing some refill canisters to start. If that doesn’t help, they’re going to the shop and getting sniffed.
derekj
Powell River, BC
Just a heads up - a lot of shops (mine included) won't touch your a/c system if you have used those cheap a/c recharge kits you can buy at auto parts stores. Those kits contain a mix of chemicals to make up the refrigerant and shops don't want to contaminate their pure R134A - plus if you use the leak sealer additive it can plug up the a/c machine as well.
CherokeeLiberty
Northern MN
Good to know. I was sure to get stuff without the leak sealer in it.
My jeep took a puff and the compressor started short cycling. The gauge read good while the compressor ran, then cut to 0 after the compressor turned off.
My wife’s car has a hard leak up front. I could hear it hissing as I filled it.
CheddarGau
Lower Mainland BC
The ones you get in the can are basically butane and we don't touch them either. Contaminates our systems. Advisors say yes, but I rule our ac machines with an iron fist and veto them
The gauge at zero when the compressor engages is what mine is doing. I would be interested to hear what the problem is once you figure it out.
CheddarGau
Lower Mainland BC
I can’t speak for Howard, but mine is on the low side
Static pressure can also be helpful. If that is zero, then for sure system is empty. Also pressure does not mean there is refrigerant in it. If you have pressures that are super high when running or even static/off, then that can be an indication you have air in the system.
CheddarGau
Lower Mainland BC
Air heats up and expands way faster/more, which gives you gauges that can be pinned, especially when looking at the low side.
That makes sense. Mine must have air in it. Low side static pressure was about 40 psi (once I tried to charge it), but goes to 0 when the compressor is on, short cycling. When turned off, the static pressure rises to 45-50+ probably because the air is hot. I think the system has a significant leak. I disconnected the compressor electrical connector so it wouldn’t short cycle.
65Corvair
Iowa
Took the jeep on a road trip to Moab again.
We did more hiking than wheelin' this trip, but I did manage to hit the driveshaft on a rock ledge on the Cameo Cliffs Trail near Wilson Arch.
Fortunately, RMB 4x4 (www.rmb4x4.com) south of Moab had a good used drive shaft that was able to get us home.
May not look like much damage, but it caused major vibrations above 40 mph.
The glow of the Moab while at Arches National Park at night.
Visited Carhenge in Nebraska on the way home
CheddarGau
Lower Mainland BC
Drive shafts and even the smallest dents will make for a not so enjoyable drive
Great pics though!
CheddarGau
Lower Mainland BC
The static pressure is way too low. Most are in the 70-90psi range. Short cycling is an indication of low refrigerant. The 45-50 confirms it. You can get it recovered, hook up a nitrogen tank (use a regulator) fill the system with nitrogen, then go around with soapy water(you can also use a special ac leak spray, its much thicker and sometimes the only way you can find some leaks) and hint down your leak. Repair then go get it re-charged. You can also leave it in a few days to see if the static pressure begins to drop
LFX1
does this ride hard with crd springs, what rear and front bumpers do you have. tire carrier looks different, off set, is that factory? Nice Rig
These arrived today from a junkyard on the eBay. Some poor old Nitro doesn’t need them anymore. o_O
I have them soaking in Free-All in the back yard, probably for the next 5 business days (which YouTuber did I just channel there?)
I need the clevises, as well as the top plates and maybe the spring isolators, although the isolators look kind of old and dry rotted. I am sure Free-All isn’t good for the rubber either. I will probably order new isolators. The clevises and top plates will get cleaned up and painted.
Just for comparison… here is a new Old Man Emu 2927 spring. It will be squished down to the same height when the struts are assembled but check out how many more coils there are vs. stock. It should provide 2.5 inches of lift over stock. (I got OME shocks too, but they are not in the picture.)
Cheers, - Lauren
