Okura_hubby
This issue started once I changed fluids.
I just changed filter/fluid. I just checked on an outting and couldnt see the level so I added a bottle and it is in the marks of Hot. so..
But issue is when engine/trans is cold. When you put it in gear and start it appears fine, and first few stop signs it acts like its out of gear then it starts.
I changed fluid in transfer case too ATF+4.. I filled it til it started coming out the top filler hole.
Thoughts? Whats going on?
