Towbar/Winch
GBsKJ
Waiting for all my suspension parts, new tires to arrive.
I had been wondering what was behind these wing nuts. Discovered I have a Roadmaster front towbar system. At least the parts that are attached to the Jeep. I could of sworn I saw somewhere recovery shackles that could be mounted into this? Also, this Roadmaster kit is bolted into the frame at a few points. Would this be strong enough to think about using to make some type of winch mount, using the Roadmaster connections?
(The spots on the pavement are from another vehicle)
Anything is possible (almost)
Depends on how it is bolted on, if it extends side to side and what you can cut off and have enough to weld to
