Strange noises
voxx
STL
My first post so please don"t butcher me; I replaced all the brake calipers and pads during x-mas and for a little time everything was grand until about two weeks ago, from the passenger side back tire I hear a noise wwhen going over anything that would not resemble a smooth surface. Im use to fixing things my self but to get a garage to do so is a pain, if anyone might have an idea and it is easy I will take care of it myself, if not thats coo.
Sound description: Not really high pitched or grinding; sounds almost like something is slamming against something.
Thanks for the help and feedback
Atrus
Metro Detroit, MI
Did you remove the caliper bracket as well? If so, the whole bracket with caliper could be slamming around. I had this happen on my old car. Couldn't figure it out until I tightened the mounting bolts up really tight.
ShafferNY
Ticonderoga, NY
Welcome to the forum.:D
It doesn't necessarily sound like it's a brake problem since it only does it when you go over an uneven surface. Sounds more like a suspension problem possibly.
I would certainly recommend checking all the bolts you took apart, but I would also check the shock and shock bolts on that side.
If your shocks are old, they could be bottoming out. Welcome!!!(welcome)
