Skis
JeepCoMJ
SE WI
So here's the deal.
I have a liberty made from two. The body I used had SKIS. the donor did not. I do not want SKIS and need to know which computer must be swapped to delete it.
The liberty now has the dash harness, dash, fuse box, and BCM from the one that did not have it installed.
I have tried swapping ECU and TCU to no avail. It runs with the ECU,TCU, and BCM from the donor in it, but still requires that the SKIS sensor is hooked up
The only computer I know of that has not been swapped is the one under the center of the dash, presumably the air bag computer.
Any help here would be great. I'm not about to go drop $60 or more on spare keys, plus dealership fees to have it set up since I only have one, and can't program a new one myself unless I have two.
Thanks
JeepCoMJ
SE WI
whichever....either way, I do not want anything to do with security chipped keys. pain in the butt.
I've swapped the ECU and BCM. no dice, it's gotta be somewhere else.
teckman02
trotwood ohio
with all the swaping of parts that you are doing from the different KJ's the DRB 3 will be your best friend get yourself some copys of the KJ FSM's you should be able to find them online for free easy as pdf's
teckman02
trotwood ohio
So you can reprogram your BCM for the SKIM you should be able to get the SKIM codes you need to go the dealer and give them the vins
JeepCoMJ
SE WI
I get that.
I really just need it dumbed down for me; where is the information for the SKIM stored?
Is it possible that leaving it plugged in, with the key in, battery connected, but ignition turned off might have set the renegade's computer to think it requires the SKIM?
JeepCoMJ
SE WI
PCM= ECU?
then how is it that the ECU without SKIM only works with SKIM plugged in?
