Rusted Rockers
Mjewell
Upstate ny
Just got in a set of new slip on rocker panels for my 2003. I'll be cutting the others out and spot welding the new ones in. Any tips to prevent further rust infestation? I plan on painting the parts inside the vehicle and using bed liner on the outside, fogging oil internally
Phil + Neela
Vancouver, WA
Plenty of ways to prevent rust. Lots of people rinse their undercarriage frequently when there's salt on the road.
You can also stop the rust with POR-15, then do a nice coat of paint over top or rinoliner. As long as it stays coated, it will significantly help prevent rust.
The key is not having any bare steel.
scbenoit
Barrie, ON
How did the rocker panels go ?
Hi Mark
How did the rocker panel replacement go ? I need to do mine on my '04
Any pictures to share ? And any tips?
Steve
Mjewell
Upstate ny
rocker repair
Hi Mark
Steve
They came out pretty good, not perfect but way better than what it was, lot's of cutting, grinding and welding. I'll try and post some pix soon
Logan Savage
WV
Why are they called slip on if cutting & welding is required to install them ?
jeepbeep
US
drill drain holes and use a cheap spray gun to coat the inside with motor oil.. Maybe that black "miracle" paint instead of oil?
The motor oil idea I've heard a few body shop guys suggest.
Heavy use of epoxy-primer doesn't work though.
