Rocky Road
Marlon_JB2
Kombat Edition Jeep
Harrison Township, MI
Avoid their Rocky Road OTT Lift. It's a piece of crap. Of course buy it if you want to destroy your Liberty's suspension quickly.
Eddo
USA
The OTT kit has been re-named the Budget Lift. Same thing thought. There other stuff is supposedly good. Some complain about customer service. I've ordered a few things from them and never had a complaint.
grogiefrog
Near Indy
Geez... Mr. Negative! [-X
Marlon, how about explaining more why it's a piece? \:D/
myjeepwalks
I've read in the lift kit discussion forum it's junk too. #-o It's the typical spacer lift that is ok if you dont plan on taking the vehicle offroad. The problem is it doesn't come with longer bump stops to keep you from bottoming out the front struts under suspension compression.. Their combo kit is good though, i plan on getting that, rancho shocks/struts and tires with my income tax return. \:D/
Jeger
OH, Dayton
All it takes is longer bumpstops to fix it? That is my understanding. If you go in knowing that then the lift is just fine. So the kit is not junk, like say the RK 7up kit was. It just needs a longer bumpstop. It still wouldnt be my lift of choice though.
myjeepwalks
True, i guess you could say its not junk becuase it works. But there are alot of other choices out there. From what i've read the OTT lifts are good for looks and to fit larger tires under the liberty. If you plan on wheelin just buy a coil lift.
