help. ive never had an issue with my jeep until now. i knew the switch was going bad as the accessory positions wouldnt work.
so i replaced the ignition switch and the actuator. it still does the same thing.
today trying to leave work i crank the engine and let it warm up for about 2 minutes, then it stuttered and died. its not cranked since. even after i replaced the ignition parts and yes the metal in the actuator was broken so that did need fixing. but still it wont run. the position of the switch works in all areas now so im sure i got it in correctly.
the engine will turn over very fast as the battery is new but it wont run. never even tries to hit a lick. its almost as if no gas is getting to it.
going to try the key trick to get a code....update coming with code.
UPDATE: cant seem to get the key trick to work for the codes. its on off 3 times right?
also just thinking since the actuator was broken when i pulled it apart, is there any chance the fuel pump fuse blew due to the screwed up ignition? like i said earlier, the engine ran fine, then died after 2 minutes of a warm up. it did try to run after i disconnected the battery a few minutes later to reset anything. but still nothing since.
