removed each lower control arms , torched the rubber out and cut the metal sleeve wasnt too bad. I know ill need an alignment for sure, my questions are will the alignment and the new bushings settling in lower my ride height ? sitting at 23 DR and 23.25 PS and would like for it to be down at least below 23.
i tightened the cam bolts when it was up in the air....probably a mistake but will be corrected with alignment if so. Everything else was with full weight.
should i remove a clevis ring ( currently at a hair over 2 per side, or will it settle enough
