Fired
I have it on good authority that these can be reused multiple times. In a year or two when I need another one I will rob another Girl Scout and steal her cookie money.
Excellent gasket, reusable and keeps everything clean, huge time saver if you pop the diff cover oftenI also have one of these on the way:
Lube Locker Chrysler 8.25" Differential Gasket
It came highly recommended by TCLiberty and looks like a time-saver.
EDIT: Had the wrong link before. :emotions34:
brake clean evaporates rather quickly it doesn't stay in the diff, I don't know why everyone is complaining about cleaning RTV off the diff and cover. Get a wiz wheel with a scotch brite pad and it takes 2 seconds
If things go smoothly I might take a crack at the Transfer Case and Power Steering fluid as well.![]()
One last question, though I plan to go get them shortly. I was planning to pick up a pair of jack stands to make this a little easier. Then it occurred to me that ramps might be easier. Eventually I plan to have both, but if you could only buy one or the other, which one would it be?
Hard to say, since you're still stock height either would be good, of course with jackstands you have to have a good floor jack as well
Personally I like Jackstands though. HF has some good 6 tons that are solid and have a wider base than what you find most places
Your best first investment is in a good floor jack and jackstands...that being said, I have the ramps, too, and they are great for fluid changes, lube, and inspections...but useless for suspension, wheels, etc....
