Rear Sawy Bar Deleted!
Minimike
Fort Frances, ON
Yay, finally got around to removing the rear sway bar. I find the ride on our roads which are horrible is much better. Less "slamming" over pot holes. An overall softer feeling in the rear which is very nice. Anyone else enjoy their rides better with a deleted rear sway bar?
And yes I understand what a sway bar does, and no I don't want your negative comments :):smokin:
Minimike
Fort Frances, ON
yeah when removing it I noticed that it only connected to the LCA. I thought it would have been bolted to the axle in the middle... oh well.
WesChapman
N Idaho
I commute over a twisty pothole filled miserable excuse for a mountain road and I found the ride and handling to be much better with the rear sway bay removed. Also does better off road. The boy and I took the Jeep to the little off road play area near the house and for the first time, I was able to climb one of the hills in 2wd. Always before, the left wheel would spin out when I transitioned through the little gully and I would need 4wd to continue. My Scout will motor up the same hill in 2wd and not slip a wheel. With the rear sway bar removed, the Jeep will now do the same.
Minimike
Fort Frances, ON
glad to hear that. I guess Jeep's idea is a sway bar will help avoid a high speed rollover but basically makes all other times worse... sheesh poor performance 99% of the time for a slim chance of rolling over.
BjBnet
Ottawa, Ontario, Canada
good to know cause I broke a bolt last year on one side. Now I know I can remove it completely without worrying about it.
Katmandu
Troy, Ohio
Is the 1% the only negative when removing the rear sway bar ?
ridenby
Gold Supporter
Kentucky
Have been removed for a couple of years or so. Think it helps ALL areas of handling.
Miff_UK
York, UK
cheers for this, with the UK's love of speed bumps and pot holes I'd like to try this, anyone gor a photo or diagram of which bitmof metal this is and which bolts to remove ?
cheers
Miff
See the round sway bar? Steel block above lower control arms where sway bar bolts to...
Two bolts per side on the control arm to remove the sway bar.
Not best pic but shows where it mounts.
42512[/ATTACH]"]
03 JEEP KJ BIG BLUE
Perham MN
it take maybe 5 min even without an impact. just put some rust buster on it and out they come. it took me 5 min and i have a MINNESOTA RUST bolt set up lol
Billwill
White River, South Africa
What will your Insurance companies say if you roll your KJ?
I know here in SA they would love to find an excuse like this to void a claim.
03 JEEP KJ BIG BLUE
Perham MN
the full coverage insurance i have through progressive here in MN covers all modifications and aftermarket parts. i have been rear ended in my heavily modified VW and not only did they pay but the repaired the car and replaced the modifications
