John3seventeen
Compiled from info from Tom Mudd, TJKJ2002, and other sources. I take no responsibility for you cutting holes in your hood and ruining it.:icon_twisted:
First tape and cover the entire Hood & make yourself some accurate templates, and cover your windshield & roof with a blanket or something.
I didn't cover mine and spent hours polishing out little rusted bits of metal which had melted itself fast.
Also cover the engine with something that won't catch fire and that you don't care if you get paint on. And remove the under hood insulation.
Then locate your templates under your hood to the best position to clear the under hood structure.
Next using these measurements as a guide and decide on the final position on top of the hood. Tape them in place.
Mark the template outline on the tape on the hood and remove templates.
Drill your small holes and test fit the louver.
Cut large holes using tools of your choice.
I used a Dremel with cut off discs and a jigsaw with a metal blade. BE CAREFUL I cut into my bracing on the one side before I knew it.
Drill holes in bracing
Paint all cut metal
Attach hood louvers.
I used a small amount of roof cement on the hood side. Make sure to have plenty of washers for under the hood.
Paint all cut metal
