If the EPA did a test(highly doubt it) let's see the results,it should be plastered all over the web and all the auto makers should be using those snake oil plugs(which they will never).Like stated already let's see the EPA test results.
If you know how to use the Internet and a Search engine, you can do it, really, I have that much faith in you anyway. You, and some others like you (well, one) are always on the devil's advocate side, for which I will not help either of you look for anything. AND, on top of that, I don't care what anyone thinks, or says, because everything I do, works for me (and THAT, is all that matters, right?), and; I own vehicles to the 150K+ mile marks, with all original parts and gaskets. Never had an engine blow, jump time, drop a valve, break a spring, blast a rod, whatever. I read and do research, apply theory and application, and I am good to go. Smart people like me, with IQs well above the average Bear, are able to make very good decisions based on data...
What I can say, it was a carbureted motor on a Dyno, that probably makes all the difference as EFI engines are pretty much optimized. STILL? I got money to burn, so I can waste it on the plugs if I want. It's good to be the king... SO, if what I do causes irreparable damage? I can go buy another one without a passing thought, so I can drop 35-48.00 on a set of plugs, EASY.
The E3 Diamond Fire plugs, are the best I have researched and studied thus far. Looked up many videos and read plenty data sheets, how they're made and constructed; and how they ignite the fuel. They are about the best on the market, and better be at those prices. They work optimal in Carburetor vehicles, I'll give them that FOR CERTAIN. EFI? Not much worth mentioning except the emissions, for a more complete burn. I LIKE 'EM!
