Need HELP!!!
Brian
Omaha, Nebraska
How do you read codes using a key sequence? Can someone please explain and help? Much appreciated!!
I think you go Off-acc acc-off off-acc . Works on 05 and older only! The gauges will self test at this time too then it'll show Done or the code in the odometer.
An 06 you have to use a scanner/OBDII reader (autozone, etc will loan one to you for free). :)
Luke
Interloper
Bancroft, Canada
Isn't acc towards you ?
on-off-on-off-on ... is what works on mine (ie key forward)
I thought the key went Off-on-acc-start?
Can't remember, but on and acc might be the samething. Just go off/the one before start 3 times.
Luke
Interloper
Bancroft, Canada
I think the problem is you have too many Jeeps ... :happy175:
Acc is towards the driver ... ie stereo powered only
On is one forward ... ie stereo and Hvac etc powered
next is start
