Need help with "No Bus" on gauges 2005
ElecTape
Just recently pulled dash for heater core replacement. Everything went fine so I thought lol.
After finishing the install and putting it all back together I started the jeep to burp the coolant system. Jeep started fine and ran for several minutes until I shut it off. Let jeep cool down and checked coolant, added some to get to cold line and started jeep. Again, starts fine and let it run while I washed the windows. after I cleaned the windows and sat down in the driver's seat, I noticed the "No Bus" error on the gauges. OK, this has happened to me in my TJ and it was just reseating the gauge plug. so, I pulled the bezel and gauges and reseated the plug. No Joy
In pulling the dash I did disconnect a couple of main electrical connectors on the driver's side. I loosened the 10mm bolts and removed reset and retightened the two that I had messed with. No Joy
Tried....
Disconnected battery Positive overnight. Cleaned battery terminals (very mild corrosion). No Joy
Hard reset for electronics - disconnecting the battery and doing a hard reset (Touching ground and positive terminals together for several minutes). No Joy
Plugged in OBD Scanner to read codes - unable to read codes.
Check both fuse boxes for bad fuses, none found.
Check OBD connector for Bus voltage and power. Pin 4 Ground good, Pin 16 12v good, Pin 6 1.7s volts Pin 14 5.54 volts. Other pins showed 4.72 roughly.
tried reseating the gauge plug again. No Joy
Gauge Cluster reboot - Holding in the trip button on gauges and turning on the key for them to reset. No Joy
After trying gauge reset, jeep starts and dies shortly after starting now.
Checked under hood for any unplugged connectors. None Found.
Checked for ground on engine and grounding straps. All good
Again, messed with resetting the gauges. No Joy, however, the jeep now seems to run as normal.
Tried jiggling harness on gauges. No Joy
Tried to pull codes (Manual method thru gauges) Neither method displayed any codes.
At this point the jeep starts fine and runs but displays "No Bus" and gauges don't function, several Icons lite up.
How do you check for a bad set of gauges?
Could I have left something unplugged in the center consol?
Any help or direction what to look for would be of great help.
Jason Haglund
Tried....
jeep, starts and dies shortly, i once had that problem like that , with someone using wrong key in the iginition ,all keys entered have to be saved in computer if one is used computer locks up, puts it into limp mode . i dont kow if thats your problem but u can always disconnect battery and reset and program the key , something to consider.
