Misc interior lights out
Lace
Maryland
I'm not quite sure if there are lights in the window switches and lock switches, but that's only part of the problem with my wife's '06 Limited.
Does anyone know off hand if there is? It looks like there's a tiny section where a light would/should be, but they haven't lit up since she bought it a few years back.
Also, does anyone know the bulb size for the shifter lights (auto)? She lost the light there and keeps complaining about having to turn the light on to make sure she's in drive.
TwoBobsKJ
Northern Ohio
Welcome! (welcome)
Yes, there are little green lights in the lock and power window switches. I can't find the bulb numbers but I know members on here have replaced them before. They're tiny little suckers!
The only bulb number I could find for the trans indicator bulb is an "S14V" bulb in my Factory Service Manual. But that number doesn't translate into a reference number I can find on any bulb manufacturer's websites. Sorry about that.
But like the other bulbs I know there are folks on here who've replaced them before. Someone will chime in I'm sure...
doolop
here
The bulb number from a dealer is 04839738AA, there are a total of nine behind the cluster, suggested list price is $0.75 each, I normally just do them all at the same time so as not to have to keep taking it apart
I have seen LED lights out there but I can't find the part number.
Sent from my DROID RAZR using Tapatalk 2
Lace
Maryland
Welcome! (welcome)
Thanks!
From some research, it looks like the bulb for the trans indicator was EW203 which is discontinued (from what I see online) and I happened to find a replacement E74, but I can only get it in bulk @ T-1 1/2 Glass Wedge Based 14V - replacement for EW203
The instrument panel are fine. I'd actually like to upgrade hers to LED. I replaced my TJ dash lights with white LED's and she loved it. That's another thing on the list to fix. Lol
Billwill
White River, South Africa
Lets bump this up. Wife is becoming quite annoyed not having lights on her trans shifter.
Does anyone know for sure if these will work? 2 Light Bulbs Toyota Camry Corolla Sienna Climate Heater Control 98 99 00 01 | eBay
Not sure where I left off, but I had these in my watch list and remember finding somewhere that they'd fit that section.
OK 2006 Parts fiche does not have a part number for the Shifter Bulb.
2002 KJ Parts Fiche has it as "MS820083 Qty. 1 Bulb, 14V 1.4 W, Shift Bezel"
I am sure it will be the same for your 2006 Model.:33:
I can not find part numbers for the window switches anywhere.:icon_rolleyes:
Just to clarify, there are NOT lights behind the window switches or lock switches. Only switches that have lights are the window switches in the back seat. Possible this was removed after a certain year??
My 04 does, however, have a light for the shifter.
TwoBobsKJ
Northern Ohio
Maybe my '03 Renegade is the red-headed stepchild of the Liberty world. All my lock switches and window switches have a green light that shines through a slot in the switch. They turn on when the key is in the "Run" position whether the running lights/headlights are on or not.
Obviously these pics are a little dark but you get the idea. As for bulb numbers? No frickin' clue...
Lock switches:
Window switches on center console:
mmmm don't think mine ever had lights in there
Can't remember ever seeing any
Leeann
Maryland
Now I've gotta run outside and see if my '05 has them - and if not, figure out how to get them!
Lock switches:
If I remember correctly they stopped putting the lights in the switches for model year '04 and I'm pretty sure the bulbs are not replaceable so that means it requires a complete switch replacement.
All my switches also light up also.
Lace
Maryland
I think I'm going to pull the shifter apart this weekend and just check the bulb itself. Might just see if I can find a LED bulb that will fit in there. I greatly appreciate the help!
Billwill
Have you tried PN: MS820083 as I posted?
Yes a LED should work just fine...with the correct resistor inline!
