NewerJeeper
I'll try to make this short. I have no owners manual, it didn't come with it when I bought this vehicle 2weeks ago.
07 3.7 liberty power steering fluid is low, like barely reading on stick below add line. The fluid looks orangeish not like regular ps fluid. What kind does this year take and thought of it looking orangeish? Pretty sure its not the old trick of ****** fluid in it.
The wretched no ****** dipstick. I've searched all over internet. Some people said yes that 06 dipsticks work and others say they don't and some say its like a inch too long. It shifts gears but in certain speeds in the 30's and 40's it almost bucks a little. Only at certain speeds like 35 and 45 something like that. So I need to figure this problem out also. It doesn't buck as bad after all the new stuff I just put into it(read below) but still does. Almost worried maybe its low on fluid with the way it acts.
I've just put on it new muffler because old was like I didn't even have one on. Huge hole on it and real loud. New pads, rotors, air filter, changed oil and changed the most worn out spark plugs I ever seen in my life. The gap was at 98 worn out and the electrode was buried in porcelain and black trying to get spark through it and the metal arm to get spark on it was so worn thin. I cant believe it ran. So I've done a lot to it since I got it. I do everything myself.
Other things im sure I'm forgetting. Like fuel filter is inline or in tank? I would like to change that also but if its in tank... I guess that's all I remembered for now will add later if I remember anything else and will be checking back for help. Thanks
