coloradored
I have seen on some kjs that they have front 2in receiver! I have looked just about every were for one but no luck I was hoping some one could point me in the right place.
Thanks
Thanks
Only 2 ways to get one now,make one or buy a used one(if you can find them).They have been discontinued.I have seen on some kjs that they have front 2in receiver! I have looked just about every were for one but no luck I was hoping some one could point me in the right place.
Thanks
Whats that setup called for the liberty? Is it barebones?
Its probably the best setup for recovery and winch mounting short of a new bumper.
is there any thing out there that is stronger then the mopar front tow hooks or is that it, fined a used 2in front?
Ah? mine (hidden hitch) had a sticker that said 6300lbs...I've red somewhere there are 9000lbs rated ones out there.
That's going to be cheap if the demand goes up anymore for the front hitches.You can get the rear hitch from anywhere,though I would highly recommend the OEM,it's the best built one I have seen yet and not really anymore then the other,less quility versions,hitches sell for.well thats a little steep [-(
If you realy want one be patient and keep an eye on the for sale thread here and on LOST and Ebay and / or yunk yard. I got mine from another JKJ member. What year is your Libby? I don't think there are any for '05+...
You need to take the front bumper of to fit it...
The hitch doesn't stick out much from the front of the frame, the plastic fascia for the bumper sticks out/down more. Even if you mounted the hitch on top of the frame you wouldn't gain anything as far as approach angle is concerned - your bumper's still gonna drag or you'll hit the engine skid. I haven't had any problems with approaches in the three years that I've had my front hitch installed.I see that you mounted it on the bottom of the front cross peice. I wonder if you can turn it upside down and mount it on the top of that cross piece so that your approach angle is improved?
But then you cut off airflow to the radiator and you will see the engine temps rise while crawling in 4low.i was thinking about approach angle with a winch mounted. I've been reading the winch cuts down the approach angle so i suggested mounting it on top of the bumper instead of the bottom.
