ThunderbirdJunkie
Bronze Supporter
I look forward to hear about the re-build when completed.
I would agree with the "borrowed time" over 100k syndrome.
Then how do you explain the plethora of 3.7s with over 200,000 on them?
Yes I've seen way more 200k+ 3.7s than dead ones.
Not going to harp on the oil changes but it could have accelerated the problem.
Ever change the coolant? Since HOAT coolant in our KJ's is based off of Ethylene Glycol it shares the one big disadvantage of it also,electrolysis(goggle it).Granted it takes longer for it to happen with HOAT but still will happen and very prone in a alloy head/cast iron block engine and kills head gaskets,more so the metal ones like our engines use.
#1 reason why I have flushed my coolant 4 times in 8 years and 70,000miles.
Whats with all the sudden deaths of the 02' KJ's lately??
Budke - Did you ever get a solid answer as to what failed that took your motor out?
Prospect - Will be watching anxiously to see what failed in yours as well.
I'm starting to wonder about the 02's, thats two on here that died, and i have seen a few 02's on eBay with blown motors. Would be a good idea to determine whats causing it, maybe some preventative maintenance can prevent it from happening to others.
Well it sat in storage for a total of 2 years(2 one year deployments),that kept the mileage down,and I have no life and rarely go anywhere.Amazing what a low-mileage Jeep you have. I mean, what do you only drive it to the auto parts store to buy more oil and coolant?
Having aluminum heads has nothing to do with early failure.The most high strung engines in the world are all alloy(top fuel dragsters/funny cars),puts the same stress on the engine in 4 second pass as does driving 100k,goes 2-3 passes before rebuild,and rarely ever has a top end failure(mostly spark plug failures,nothing mechanical with engine).Never had a issue with the alloy heads on my Olds 350,went over 100,000miles and was driven extremely hard(spent most of it's life well above 6000rpm's) with .750" lift cam and 13.5:1 compression ratio.I still say you are on borrowed time after 100,000 miles or 160,000 km. Lets put it another way, you have done well if you get there without any failures especially on gaskets & springs w/ aluminum heads.
There is just too many variables and potential manufacturing defects, as well as driver behavior and questionable maintenance by many owners. ( I am not implying us we are informed and care enough to do good maintenance)
How many hours and revolutions has that engine turned at 100,000 miles?
Chrysler Canada offered a 7 year or 115,000 km (70K Mile) warranty.
Hell if I know but I have an 02' as well and its got well over 120k on the clock, and it runs like a top. It seems to eat oil at an alarming rate, but the coolant looks fine, it doesn't smoke, clank, tick (aside from a fresh cold start at anything below freezing, even then it only lasts for about 10 seconds), it's got large amounts of power, and she purrs like a.. very fat feline.
Not sure where the oil is going, but she doesn't produce any noticeable smoke and the coolant looks nice and clean from what I can tell.. sucked some up into an antifreeze tester to check temperature handling and it looks nice and clear.. and green.
I rattle on about how great it runs.. and watch- I'm gonna go start it here in about an hour to go home from work and the engine will catch fire and fall from underneath the hood eek2.gif
Green?? Why do you have that crap in your KJ?? HOAT only...
