"People" in general do not take care of the basic items on vehicles,guns,etc.
Not a dig at OP, responding to kb0nly's post.
Yeah your right, but some of these failures are regardless of owner treatment. I watch eBay for KJ's all the time, i keep telling my wife jokingly she should get one and have matching vehicle, but anyway i like looking through eBay to see the ones that have been modded and are for sale as the owner moves on. The disturbing thing is the 3 or 4 02' KJ's i have seen with motor damage. I think one might have been an 04' but unfortunately after 90 days on eBay you can't view an ended auction so i cant look back again.
Anyway, one stood out... I remember reading the description because it was like a page and a half long. This guy had everything done from the dealer, every maintenance item checked off, meticulous records kept, the KJ itself was immaculate in every detail, and it was only about 800 miles away from me, yeah i considered buying one to put a rebuilt motor in or rebuild the motor in it in my spare time. But anyway, that guy had a fairly similar failure, running fine one day and rattling the next on the way to work. So i'm guessing there is a connection here.
Now i'm not saying that 02's are junk or have bad motors, its merely that most of the 02's on the road are 100k plus miles and starting to experience failures related to age and wear. Now since my 03' isn't much younger i want to keep an eye on the track record of these higher mileage 02's to give me some insight as to what might happen.
Ok, maybe its head gaskets failing, if that's the case then we need a good sample of the mileage at which they are failing, if its over 100k then maybe at 100k we should consider new head gaskets even if there is no sign of failure yet. Thats what i meant by preventative maintenance. As an example on the 95 Neon i had you pretty much had to do a tear down at 80k and replace the timing belt and water pump, as the pump is driven by said timing belt, and as long as your tearing into it you might as well pull the head and replace the head gasket if it hasnt already failed. They had a problem with head gaskets failing and the cure was a new multi-layer head gasket. I did all that on that car, and despite all its weird problems over the time we owned it the motor was still solid at 160k when we got rid of it.
