not that I know of but the fuses are the all blacks so im assuming that you can't tell if they are blown or not...so gonna try replacing all of them
What do you mean all the blacks? The large black cubes are relays...there are fuses next to the relays under the hood and also fuses in the fuse box inside the cabin. You ideally need a Multimeter to check the fuses.
Check the small connector going to the alternator has not pulled out...this controls the charging rate...controlled by the PCM.
The large thick cable coming from the alternator to the positive side of the battery actually has a "fusable" link inbedded inside it near to the battery terminal. This is a type of heavy-duty fuse that will blow if you touched that wire to ground with a wrench while doing your repairs.
You need a voltmeter...put the black lead of the meter to ground some where.ie. the engine or use the negative terminal on the battery. If you place the red meter lead on the battery positive lead you should read about 12 volts (DUHH:jawdrop
. Now if you move that red meter lead along that fat wire going to the alternator you should also expect to see 12 volts unless the "fusable" link has blown!
