thegapgal
I have a 2006 Jeep Liberty. Ever since I bought the vehicle 1 1/2 years ago I noticed that the illumination panel lights often go on for no reason and eventually go off. For example, the lights that indicate 2WD vs 4WD drive go on even when I have not engaged the shifter.
Or the gas cap light when on and would not go off even when I replaced the gas cap. I finally had to disconnect the battery for the vehicle to acknowledge the new gas cap.
Recently the CHECK ENGINE light went on though the car had been recently SMOG tested and passed and was running well. So I again disconnected the battery and the CHECK ENGINE light did not return.
The above has happened to me twice!! And thoughts or ideas on what is causing this??
Thank you,
J
Thank you,
J
