It's right there in the pic on the right side middle
Oh, duh. Thought that was something else.
Glad you got it figured out
Ok so when I try to get the bolts out the shaft keeps spinning. How should I go to get em out?
EDIT: Nvm I got em. Just gonna wait till later in the day when the sun isn't out. I'm sweating so much I could fill a pool!
Probably found out that one or both of the front wheels have to be still? (I only had 1 wheel off the ground when I did mine, driver's side.)
Ok well first off welcome! There should be one cap on the side of the T-case. It bulges out and has a small hole in the middle. BlueKJ is holding it above. This fits quite snug. I had to wrench it on with the bolts that hold it all together. Could you please provide a picture or two of the joint? I am having a hard time picturing the problem.
