mercdudecbr600
- Joined
- Oct 3, 2018
- Messages
- 417
- Reaction score
- 148
Hi all. For the last 5 years or so I’ve had a lifted kj. Nothing crazy, just the ome lift with no spacers.
After regearing to 4.10, I’ve got vibrations through floorboard at 70mph+. Had both driveshafts rebuilt or replaced but I continue to get the same at high speed 70+. I Have gone through a litany of new parts, wheel bearings, intermediate shaft, cv axles, oem mounts which did help significantly but it’s still there.
Having pestered the driveline shop enough they finally started asking hard questions like, what is your rear pinion angle relative to your tc output shaft, and your u joint operating angle?
Long and short of it, I’ve got an excessive u joint operating angle at something like 5-6deg. Supposed to be 1-3deg.
And since I’m not the most extreme of lifted kjs figure others here MUST have figured out a solution.
Mind you, this only came about because I’m now spinning 24-2500 rpm at 70mph. I’m guessing I always had this issue after lifting and didn’t realize it because with 3.73 and 31” tires, I never got to the propshaft speed necessary to vibrate.
Help and/or thoughts are welcome!
