Hoat
Discussion in 'KJ General Discussion' started by Tog, Jun 16, 2016.
  1. tommudd
    tommudd Moderator Staff Member Moderator
    17,064
    143
    You'll pay, maybe not now but later
  2. BorincanoKJ
    BorincanoKJ Full Access Member
    112
    Feb 11, 2015
    San Lorenzo, Puerto Rico U.S.A.
    Green coolant is not the problem.
    The problem is not having HOAT or OAT in the coolant.
    Regards!
  3. uss2defiant
    uss2defiant Full Access Member
    3,296
    isn't HOAT different from OAT too though.
  4. HoosierJeeper
    HoosierJeeper Gold Supporter/Admin Staff Member Administrator
    20,621
    35
    Right. I just know that Prestone stuff in the yellow jug that happens to be green isn't HOAT.
    Two different categories of coolants.
  5. BorincanoKJ
    112
    Feb 11, 2015
    OAT and HOAT antifreeze is designed for use in aluminum radiators and components.
    Some HOAT formulas claim compatibility with certain OAT formulas or IAT formulas.
    Organic Acid Technology (OAT) and Hybrid Organic Acid Technology (HOAT). Both may be referred to as “extended life”.
  6. profdlp
    profdlp Grouchy Old Cuss
    4,820
    100
    Like a number of others have mentioned, the way to determine it (and be sure) is to flush it and fill it yourself. I had a flush done at a place I trusted who swore their universal stuff was a HOAT replacement. (I had owned the Jeep for about two weeks and didn't know any better.) A year later I was replacing my water pump - at 58,000 miles.
  7. tjkj2002
    tjkj2002 Full Access Member
    10,614
    Dec 17, 2006
    You can't buy IAT coolant anymore so anyone claiming the "green stuff" or "regular coolant" is IAT they are wrong.
    You either are buying/using OAT or HOAT coolant.
    HOAT coolant is compatible with IAT coolant,both are silicate based.Only main difference is IAT coolants must be changed every 1-2 years.
    OAT coolants are silicate free.
    Depending on the design of the engine(gaskets and such) you either require silicates or not.Chrysler systems require silicates.
    Oh and by the way Prestone does not make any HOAT coolant at all,99.9% of there coolants are OAT.
  8. Madlh24
    Madlh24 Full Access Member
    38
    Jun 20, 2016
    Southern Arizona
    Just got my jeep a week ago and when I i first checked the coolant,I thought it was water. When I went to go buy some coolant (zerex g05) I noticed it was a clear golden color, when finally mixed 50/50 with water, it looks like... water...I went ahead and stuck my finger in the reservoir and did a taste check with the tip of my tongue and it was sweet. Ha, I had never seen a coolant that clear before.
    For reference
    http://www.wranglerforum.com/attachment.php?attachmentid=2636745&stc=1&thumb=1&d=1448072390
  9. CactusJacked
    CactusJacked Full Access Member
    2,409
    Dec 12, 2013
    Chicago Suburbs
    Hate to be the one to break it to you, but you only have one week to live. HOAT stands for "Highly Offensive And Toxic"! :happy175:
  10. Madlh24
    38
    Jun 20, 2016
    Southern Arizona
    Oh no! Goodbye everyone :Bye:
  11. Kal-El
    Kal-El Full Access Member
    538
    Dec 19, 2015
    Glendale, Arizona
    Can I have your Jeep?!?!?
  12. Madlh24
    38
    Jun 20, 2016
    Southern Arizona
    You'd have to fight my wife for it!
    You--> :lazer: <--My wife
  13. Kal-El
    538
    Dec 19, 2015
    Glendale, Arizona
    :hidesbehindsofa:
