Front passenger window stuck closed
AVR2
UAE
A while back my wife noticed that the front passenger window in our 2005 KJ Limited was stuck in the closed position. When you press the switch, you can hear the motor trying to work but the glass doesn't move.
We've lived with it but it's time to pull the door panel and see what's going on.
Since it's not the usual problem of the window falling into the door I'm guessing that it's not the plastic window bracket (I've already fixed both rear windows with the Steiger metal replacement bracket), but does anyone have any suggestions on disconnecting the window from the regulator with the window all the way up?
I guess I just have to do it blind and feel for the little metal clips, hoping that there's enough space to get my hands and some pliers in there?
markc
Texas
Are you sure it is not covered under extended warranty from Chrysler? I know 06-07 models are, having had mine fixed twice for free already, on a rear window.
